Orange contracts for p900
4 replies · 2,112 views · Started 10 November 2003
How long do you have to sign up on a new contract before you can change talk plans
ie buy phone on your plan 200 at 299.00 then move to your plan 60.
it depends on the dealer, if you buy directly from orange, then it's 1 month, if you buy from onestopphoneshop, then it's 3 months even though they say four, and carphonewarehouse, i'm not sure, the link, it's 1 month,
I got mine on Talk 200 for �215, look around for better deals rather than buy direct from Orange IMO 😉
if you buy the phone from orange direct, they will let you change the tariff after one month, but if you buy it from a dealer like off the internet, they will probably restrict the tariff change, it works out roughly the same in the end because the tariff cost makes up for the cost of the phone, but if your getting the phone heavily discounted because of the tariff you're going on, you will more than likely be restricted to stay on the tariff you signed up with for 3 months. i think wil onestopphoneshop, (the internet place), they say that you have to stay with the same tariff for at least 4 months, but you could probably change it after 3 months.
