Tracker and Memory Stick
2 replies · 2,011 views · Started 12 November 2003
Probably been asked before but can Tracker V3.1 and associated skins be run from a memory stick or does it have to be from main memory? I have just today bought this and would rather put it on the Stick rather than use up my precious memory!
Doug
when you install tracker, if it gives you the option to either install on the c or d drive, then yes, you can install install it onto the memory stick, i can't remember as it was so long ago i last installed it
