Smart Launcher work on 6600?
10 replies · 6,122 views · Started 13 November 2003
HI!...
i have a 7650 right now and i am thinking to upgrade
to 6600 ...
But, just wondering if Smart Launcher work on 6600?
Anyone try that?
because i love my actual icons and look on my 7650..
look the attached pic ...
And anyone try Remote s60? .. on 6600? ...
work too?
thanks!
cya!
OK!>. i know that 6600 you can use Themes...
But.. show me a theme like mine 😊 ...
How you can create themes? ..
can you change and customize your own icons?...
6600 came with the app to customize themes?...
thanks!
cya!
AEFOX,with the native themes support you can skin a lot more then the menu and menu icons in the 6600.
Yes, the standard themes program goes way further than only the main menu. Just wait till Nokia (finally) releases theme editor.
any dates?
hey guys you could actually modify the climber theme... all you need is a bmconv application and the climber.mbm to parse... but its a pain in the ass to edit since climber.mbm contains 360 bitmaps.. but its worth if you got it going...
