Hi guys, I'd like to know what's the best MMC for 3650 and if there's some kind of maximum size to use it. Can I use 128/256MB or it's works better with 64MB?
One more: What MMC model and size do you use?
Buy a 'Kingston 128mb MMC' Cheap, reliable and 128mb is more than enough for storing goodies on your phone.
For cheaper and higher capacity MMC's try www.tecic.com.tw
Thank you guys... but one more question: is there any incompatibilitie with the MMC's size or type? San Disk, PDC, Simple Tech, Lexar, Viking, etc... which one is better?
Arni and Ghost Dog what MMC r u using?
Lucs,most 128 MB MMC should work.As for higher capacities i don't know,tecic seem genuine.At the moment the only MMC i'm using is the one that came with the N-Gage but i'll be geting one from tecic ASAP.
I use San Disk MMC (128MB) & it works fine.
When I have asked about other good brands TEC (128 & 256MB) (which ghostdog mentioned) and Memorex were ones that were completely compatible.
Unfortunately San Disk do not offer a 256MB card yet, but plan to do one before Q2 next year.
M
Is there some MMC we must avoid at any cost?
I have this options here at my country... which one I should buy?
This one
Its an SD card,not MMC so it won't work with the 3650.From the above three,get the cheapest 😉
Oops! U r right! I forgot about that! Thanks Ghostdog!
That IS an MMC. Says it right there on the thing.
No, It CLEARLY states that it is a SD CARD, with 128MB.
The others are MMC Card, as stated....
