f-ing slow memory card
9 replies · 2,057 views · Started 13 November 2003
the 32 meg card works fine (which came with the phone), but my own 64 meg and 128 meg one makes the phone seriously slow it's unbearable, anyone know why? it just has a few programs and vids and ogg's on the memory card. :'(
okay, so now none of the mem cards are even detected by my phone,,,what the f*** 😡 it's sooo annoying
My P800 used to do this, try blowing int he duo slot, might be some pocket fluff or something in there 😊
If that fails, send it back😉
alright, i just tried that, i'll see if it speeds up BUT any app i install on the mem card, it disappears from the app list and the mem card becomes corrupt, this is only since i got the p900 :'(
i reformatted the card, and now it's okay, but then the card still sometimes says that it's corrupted...but when i insatll apps onto the card, it doesn't show, the memory of the card goes down, but it's not to be found in the apps list, however, it is in the uninstall bit of the phone, but i can't find it anywhere else :'(
as I said, guess it's something wrong with ur Phone's Card Reader, check the place u bought it from!
i have to wait till carohone warehouse manchester market street have it as i have insurance, i'd rather replace it in store than send it back to cpw direct
When you transfer files to your Duo do you use a cardreader on you PC? I have had these problems before, I think some card readers do this and what I usually do is backup the MS manually then reformat the duo then copy the back up backup, usually what happen is I loose all me media (mp3s to be exact)
