where is the inbox???
3 replies · 1,616 views · Started 14 November 2003
please help me i bluetoothed a few video clips taken from my 7650 and now want to move them 2 my mcc card i looked 4 the inbox using fexplore and had no luck find the inbox or file can some1 plz help me... cheers
Your inbox is your message inbox.
Messages --> inbox
If you send it via bluetooth it shud go straight to your inbox.
go to c then system then mail then the first file
u will get a lot of files look in them u should find it😉
If you are moving files to the gage, i recommend installing fexplore . bit the files are where you out them... In root If you use the usb it is probably e:
