Got my SMS in the Outbox at �WAITING� status all the time not until you manually press �Send Now�. Setting is set to �Send Messages � Immediately�. V3.18
Sometimes the problem was addressed by deleting ini files or if not, reformatting it. Anyone out there can figure how to solve this problem? Got this problem the second time around, I guess there must be some files that are responsible for this. TIA. -dayv
IIRC correctly this may be a bug that is fixed by firmware 3.62 (it rings a bell somewhere).
Aside from that I'd suggest a reinstall / reset.
Rafe
3.18 (messaging application) crash sometimes when you reply to SMS.. maeby this have something to do with your 9210.. I suggest that you upgrade it to 3.62
Regards
thanks guys!
i've been keeping my 3.18 version coz i'm undecided on what version number to upgrade to. everybody points to 3.62 so far, so i guess i'll go for it.
maybe 3.62 is far the more stable one... regards. keep up the good work man!
