can anybody tell me how to put music onto my p900?? I have used windows media player to transfer files onto the memory card but on the p900 there is an apauling stuttering sound and clicking over the music (which is barely audible).
The manual is not very helpful.
I use windows xp and have a card reader
i would say put memory stick back in to the phone & use SE pc suite to explor P900 useing windows explorer then drag & drop
in to memory stick
why don't you use your card reader?
it's ok it was a fault with the phone. I have exchanged the phone and rectified the fault. It was a fault with the speaker.
Thanks all!
