Can you use 256MB & 512MB SD cards
5 replies · 3,202 views · Started 15 November 2003
Does anyone know if the A920 can accept 256MB & 512MB SD cards or is it limited to only 128MB like the P800
I have a 256mb in my a920, works a treat. Couldn't tell you about the 512mb, although I have heard that they don't work.
Thanks DanielF.
Does the brand of SD card make a difference or are they all the same?
When I got my A920 I was asking the same questions as the handbook states that the phone can take a '128mb' card. Apparently, someone replied saying that it was the largest available card at the time of printing the booklet and the phone will support any size card that comes out. Another chap said he was going to buy the 1 gig card as soon as it came out.
Im running a 256 with no problems- (sd make)
I have the Viking 1gb MMC SD card in the A920, works a treat, got 12 hours of music on the card at the mo, Also managed to use the MP4 converter to size down a film and fitted it onto the card for a long train journy. Very good
