best mp4 convertor for a920
3 replies · 4,805 views · Started 15 November 2003
the best suitable MP4 convertor is pvauthor from www.packetvideo.com ,we can download trial version,i found the best setting to be the H.263,150kbps,10fps,i found it takes less memory,higer the setting better the picture quality but more the memory,
enjoy
raju
I find the best is mpegable..... go get it and try it out..... i will put money on the fact you wont go back....
i managed to get a full version of mpegable but it doen't seem to work. it seems to encode at a good level but when i transfer it to my (reflashed) a920 it says its unable to play?! Any suggestions?
strip o duck wrote:i managed to get a full version of mpegable but it doen't seem to work. it seems to encode at a good level but when i transfer it to my (reflashed) a920 it says its unable to play?! Any suggestions?
You need to change the graphics and sound to work best with your phone.
try these settings
codec:h.231, 176x144, 150kbits a sec (200 seems nice to me as well)
audio: acc 96kbits (above this the audio does not sync when entering full screen mode on the phone.)
Also try lowering the frame rate to 12.5 or 12 (the a920 can support upto 15 but has difficulty with sync at fullscreen.)
Hope this helps 😃
