I've got problem with my p900 & Bluetake bluetooth adapetor
it cant finde my phone but by phone can when i try to pear from phone it ask for key then after while it says pairing fail
any help
P900 bluetooth problem
Did you enter the key?You have to enter the same key on the phone and PC in order for the devices to pair.
yeas i did but nothing happend it keep saying faild. It was fine with my 6600
thanks for the replay😉
I know, can't get my bluetake working either. Worked fine with my T68i before, but now I just can't seem to get any COM ports working, or even get the two of them paired.
Shall I give up and get another BT dongle for the PC - what are other people's experience?
I don't know whether it's this god awful sh1te by Widcomm, or the dongle itself - is there any 'free' bluetooth software out there?
It is a bug in the phone it self spoke to orang they told me contact SE my phone is still under 28 days dont know what to do😕 😡 😡
don't think it's from the phone, it's a matter of comapibality (I guess), so to b %100 sure, just try another BT adaptor with ur P900 , or try another P900 with your BT ad.
I've got a BT ad. which works fine with my P900 as it was fine with P800 b4
I bought new one ad from TDK same happend i also try with my ipaq same happend my friends P900 is working fine with all adapetors thats why i thought it's bug + have a look this post at expansys
Phone: CXC162022 R3B004
Bluetooth: CXC12529 R5D
Organiser: CXC162021 R1C01
CDA: CDA162004/3 R2B01
http://www.expansys.com/forumthread.asp?code=107853&thread=41&man=SERIC
well , guess it's a phone bug then!!
by the way my Bluetooth is CXC12529 R5B
didn't update it yet, and it's working fine with my MSI Bluetooth adaptor😊
I tested it with my Billionton BT dongle and it works fine. Im currently using the built in bluetooth on my Sony TR2 laptop (japanese version is the one with bluetooth built in) and so far I have no problems, infact with the sony tr2 built in BT i can even have a succesful serial port connection unlike the Billionton and MSI dongle that I tested before which gave me an error then a connection.
