Hello everybody,
have some you the VPN tunnel to connect to a company server? Must I install a new software?
Can someone help me?
Thnak you very much.
Best regards,
Dirk Endter
Hello everybody,
Best regards,
Dirk Endter
Instead of vpn you can try SSL connections.
Nokia has new products and no client sowtware installation is necessary.
Or if you have Nokia platform and Check Point software there is also solution.
http://www.nokia.com/networks/product_catalog/pc_subcategory/1,6935,105890,00.html?tech_id=
