I was wondering if anybody knows if it's possible to reflash our phones?
Mines got this Voice System Error whenever I try to record voice and I'd like to get to the bottom of it.
You'll need a DCT4 flashing dongle which is very expensive and the firmware flash file which is hard to find since Nokia doesn't release the to the public.So probably no.
that you could type *#7670# or something.. i did this with my 3650, and that worked fine.. shoud work with 6600 also?
Actually what worked for me was *#7370#
There's another one that's a more shallow reset but the above is a deep reset.
That is not reflashing,that is reseting or formating.
