I just bought a 64MB card for my 9290, but I can not figure out how to format it... Is there a formatting utility out there that I can use and then just move my old info over?
:x
:x
It should come preformatted but if you want to format it, select the MMC in filemanager, then there is an option in the menu to format it.
I got a generic MMC Card, are there only certain type that will work? I will try to format it under windows and see what happens.
All MMC cards are the same. Well except for the amount of space on them. There is only one filesystem which is why it's usable in any device with an MMC slot.
