can anyone help with the following please.
i want to swap over data from a 9210 to the p900 can this be done without putting it all in by hand including the memory cards?
does anyone know if i can get the p900 on 02 with a new contract as i have been told only orange are are the only ones who have approved it.
thanks for any help provided
regards
Ph236
yes, orange are the only one's who have approved it at the moment but i'm not sure how stable the handset is, i've had lots and lots of problems using the memory stick duo with my p900 and random shut downs saying that they would restart to improve performance, lalala,
oh yeah, you'd have to back up the communicators data onto your computer say onto lotus notes or microsoft outlook and then transfer it from that to the p900, the communicator is running a different version of symbian so i don't think the data is compatible.... or is it? 😕
