Unlocking keylock using virtual keypad
4 replies · 1,926 views · Started 17 November 2003
Am I the only person having this problem? When the automatic keylock kicks in, the only way I can unlock the phone is by using the jog dial. If I try to use the virtual keypad, I get *absolutely* no reponse from the keys at all. I can't see any options that may have made this disabled. Any thoughts?
i think this is good that you have to use the jog dial one way, then inwards, as opposed to accidently key pad pressing to unlock it
I think that is the way it is designed. I must admit it does'nt bother me you soon get used to it. Infact i find it easier
But surely it is WAY easier to accidently unlock your phone using the jog dial as opposed to the screen. I'm unimpressed something so basic doesn't work, I have to say...
