I cant seem to find anywhere that'll give me the total amount of time used on the phone. I found a log in the call menu. Just doesn't seem to give me total time.
I'm on a 3,000 minute plan with Voicestream and i'd like to reset the long once a month.
What am i missing?
Thanks..
You can check this from the phone display. Under the menu "Call register" there is an option for call duration, which lets you as well clear the timers.
(push menu 2 5 4 ("dialled calls' duration"😉, shortcut to get there)
HTH,
Tilman
Sometimes it is easier and faster to check this forum... 😃
