HELP! My phone won't swith ON: "App Closed Phone ViewSrv 11" appears...
4 replies · 2,277 views · Started 17 November 2003
Hi guys what can i do here?
I just uploaded pics thru iR to my MMC then it suddenly froze so i took the batt out, then when i switch it on, it stays on the white-background/Nokia screen for about 2 mins then asks for the PIN then upon entering it, everything seems fine, BUT this error msg appears after about 20 secs....
Is there anything i cud do to fix this? Thanks
i'm noty sure about how to do this, i don't remember what I did exactly !!!
but maybe pull out the sim.. start the phone, and if you can enter the reset code..
*#7370#
it might ask for a code, which is 1 2 3 4 5
this is the way to do it, i got this of club nokia...
and if you wan to keep your stuff.. well, make a backup of the apps. maybe the intire system folder
do you keep the mmc card in the phone when you do it? Take that out, take the sim out, then try it. If that doesn't work take it to your local nokia centre, or do a hard reset (make sure you have a full battery)
