hard reset
6 replies · 2,423 views · Started 17 November 2003
is there any way to format the n-gage itself then re-install al that programs it came with. i cant get photo album to work and dont know how else to do it unless there is the photo album to download somewhere...
cheers
Plug your fone into the charger and type *#7370#
When you hard reset, the phone will return to factory settings. All your contacts, photos and such will be deleted but everyhting else will stay the same.
by default your contacts is stored in the internal phone memory so if you format or hard reset your phone all is gone. however you can backup your contacts before you reset your phone
