Which bluetooth adapoter?
3 replies · 1,485 views · Started 18 November 2003
Hi can some body tell me which bluetooth adapetor works fine
with P900. Mine does not support😞 so i will buy an other one
all I guess should work with no problem, I have MSI, and used 3Com b4 with P800 and T68i (never used them with P900)
but guess ur main issue is the software used, try searching for update, or even u can use some 3rd party sw to help u.
anyway what's ur adapter? I'll try finding a sw that works with it!😉
I purchased Belkin 4 mounths back but never got it to work ok. Changed it to TDK and everything was so easy and working just fine.
