Hi
I really need help in connecting my Nokia 6600 to Microtune USB bluetooth adapter using WidComm 1.3.2.7 software. I have tried it on two computers.
1). In the first computer, it worked perfectly the first time. However, I changed the settings of the serial port and it now refuses to connect. The icon in the taskbar changes its color to reflect a link but then fails. One problem is that if in the "Services", the COM port is 10, I can't set it to 10 in the "My devices" section. Tried using the Configuration wizard, I was able to select it. When I click on "Properties", it again shows a different port. I was able to connect to fax and dial-up networking.
2). On the second computer (my home), the mRoute app with Nokia PC Suite does'nt show the bluetooth COM ports, even after uninstalling / re-installing many times. Also, fax and dial-up networking works but not serial port. Help would be appreciated.
Regards
Kashif Mehmood
