New PC-Suite (3.0) released!!!
i take it that means Bluetooth is now supported?
I'm already doing a sync via bluetooth with PC Suite v1.1. 😉Will we see improved performance and stability on v3.0? How did the version jumped from v1.1 to v3.0?
Also, there had been some problem about getting the PC SUite to work due to mrouter dll file. For some reason, after installing PC Suite v1.1, we had to take the mrouter dll file from v1.0 and manually overwrite the v1.1's to get the sync to work.
I'm hesistant to try v3.0 since mine's working well now. Anyone tried so far?
It doesn't seem any different. I've just loaded it up, and it still says version 1.2.0 when you look at the "About" menu item!
No problems connecting/backing up/synchronising........
Same here - looks the same to me.
Even uninstalled and reinstalled this version - still says 1.20
is it any new function in the new version?
whats the diffrent?
whats the diffrent?
The new version 1.3 supposedly supports Windows XP bluetooth functionality. However, I didnt notice any changes from 1.2. And, as others have stated, when I check in the "about" menu, it still says that the version is "1.2", not 1.3.
As such, I almost regret upgrading- if it ain't broke don't fix it.
I saw a major difference with this new version. I can use bluetooth to transfer files to my 3650 using the Microsoft Bluetooth Transeiver. Before this version, I couldn't use SPP, and therefore, couldn't transfer.
Mabuhay!
I missed this forum site. Well, I HATE the updated PC Suite 3.0. It prevented my internet access to go much higher than 1000KBs. Well...this only occurs on dial-up.
Anyways...long story...
Features has not changed. It does have a stable connection between my phone and the program. 😃
does this support n-gage?
Get the latest PC Suite (whatever it is) for the N-Gage through http://www.n-gage.com/
This thread is old, but incase someone's looking I'm still having consistency problems with 3.0. Not much difference with the first release. I'm using Xp. Router bogs down every now and then. Like I said. It's inconsistent. I really don't know why.
Hey. Does this version work with windows 98SE?
