problems syncronizing appointments with p800
0 replies · 1,384 views · Started 19 November 2003
This is a strange one, the only appointments that will transfer to my P800 from outlook are the ones with a repeat set on them.
For example if I set an appointment without a repeat and sync, the appointment does not get transferred to the phone. If I edit that appointment and set an annual repeat and resync then it gets transferred no problems. Remove the repeat and try again and the appointment is gone.
Any ideas.
Cheers
