Real One Video Conversion
11 replies · 2,107 views · Started 19 November 2003
Before you give me a hard time, I have looked in the forum, but have not found an answer to this (and in P800)...anyone know how to convert Real One video to the P900??
Cheers
Nick
Probably your best bet would be to get the real file back into a usuable format.
I use a program called RM Convertor try searching for it on www.download.com I think its shareware or has a 30 day trial. There is not much to compare this product to but it seems to work jsut fine. I think it will turn your RM file into an AVI or various other things which can thrn be put through whatever encoder you want...
which will probably be a packet video encoder 30 day trial from www.pv.com
not realyl sure - I only ever used this program once when I had deleted the AVI of one of my files and it sufficed, I couldnt find much other stuff out there to do it so I think it might be your best bet.....can I ask what videos you are converting becuase its an unusual thing to need to do....
P
I've done it a long time ago, but the name of the programs I used escapes me.. It is very much possible though..
pasa...only ever seen it in RM format...tried your idea though and now have Kylie on the P900!!! I can live with a bit of sound slippage!
Cheers
Nick
