bluetooth+internet
2 replies · 1,861 views · Started 20 November 2003
Does anybody know a way that i can have inet on the p800 via bluetooth??
Amd some adapters say they have radious More than 10m is that true?
Sure. Connect your P800 to your PC through a BT serial port connection (you must have PC-Suite installed and an activ internet connection on your PC), open Opera and Voila..
Yes, that's true, but the P800's BT is still limited to 10m so you still have to be within that radious to establish a connection or transfer files.
u forgot to add that u need to make sure the phone is shown as connected to the p800 software 😊
i set my com port for serial gateway to 8 and it works every time.
something i cant seem to get working is java msn via the bluetooth like. its got a http proxy setting. but im unsure as to how to set it up. if u use my pc ip and put a proxy on it will it work via that. (not sure if the phone will see my comps ip)
any help on the msn prob would be great 😊
