Brand new 256MB MMC memory card is not working..
8 replies · 5,397 views · Started 20 November 2003
Anyone have a clue why it isn't? I could swear Nokia technical support told me the phone supported it just fine.
When I pop in the card and power up the phone, I enter Menu > Tools > Memory. It says "(no memory card installed)". I even went as far as buying a card reader/writer, to format the MMC card, tried both FAT and FAT32, but the phone will just not detect it.
So is there nothing else I can do? Do I have to return the card? 😞
Card brand is "extreMEmory".
Cheers!
Hi, be sure that the usb cable is unplugged .. If the usb cable is plugged in the Ngage the MMC card will not be recognised.
good luck!
I did, why would I have the USB cable in it, in the first place, when trying out a new MMC card?
Okay, if after a restart you still do not see the MMC then you have a defect MMC or a non compatible one-1
Pasa, I got 32mb mmc card with my n-gage 😉 and many people get it 😉 and there is a game flo boarding in it 😉 well i have got 128mb card and it works for me. But my friend has got 512mb!!! and it works too. I can say 1 thing: if you buy a card over 128mb you must consult with someone will this brand of card work on n-gage.
