Battery lifetime ?
12 replies · 3,556 views · Started 20 November 2003
Hi everyone
Please let me know for how long your phone lasts ... if i only recieve a couple of short calls a day (> 5min), read less than 10 messages, no gaming og surfing, my phone lasts 4 days ...
But the specs says 240 hours ???
What about you ?
Nokia site states 150-240 hours standby on their website, and that would be ideal situation ie. pure standby with no calls or backlight use.
Neil
Also I forgot to say, 4 days sounds good to me - bear in mind Li Ion battery needs several changes cycles before it will hold a full charge.
Neil
First of all I gotta say I consider myself a hard-user. In my case I send betwen 5 and 10 sms a day, I recieve some more, I use gprs to download the mail and I use to play SonicN and GoBOy every once in a while. My battery never lasts more than 2 days 😊
I check and send email 3 or 4 times a day.
Play games on the bus, and chat on IM.
My phone is always passed around friends in the pub etc as well.
I get max 2 days, but usualy 1 and a half.
HI!..
how long time take to you to charge from Cero to Max charge?
with the phone turned OFF ...
Mine i think is taking too long 😞 ...
May be is the charger?
More than 2 hours to charge i think is not good...
but the battery then is good charged for about 2 days of use..
so.. i don't know if this is normal?.. this is the second charge from i got the phone...
that take less after more charge cycles?
thanks!
cya!
Battery lifetime:
Yesterday i charged my phone, today i didnt, tomorrow i need to charge again.. Using: phonecalls, random e-mail usage, some emame gaming, little chatting over gprs maybe. some ir use for new sounds and multimedia.
ok thanks..
but..
my question was..
How long take your phone to get totally charge..
from you plug in the charger? ...
from no charge to totally charge... with phone turned off..
thanks!
Originally posted by AEFOX
ok thanks..
but..
my question was..
thanks!
60mins max if the phone is off and 75min max if the phone is on
Originally posted by fonager
[B]
But the specs says 240 hours ???B]
Thats under optimum network calls left on a side not touched, no calls, no texts, no nothing.....
And the spec says Up To 😉 magic words
Its kinda like laptops they say 3 hours but more often that not this is the time before they die in sleep mode hehe
