I heard that we have to "side talk" when you talk on an N-Gage.
See>>>>> http://www.dromadaire.com/MarkZGR81/HoldiN-Gage
My question IS:
If you hold the N-Gage like a regular cell phone,does it still work well??? Please do the test and post your results.
BTW the "side talk" like on the photo is kind of weird and cool at the same time lol
ngage is designet to talk from the side 😊 so the speaker is on the side...so to talk like normal phone it is not ok... 😊 no need to test i think... maybe you can talk but the sound will be too low... it is like talking a normal telephone from backwards...
You can hold the N-Gage like e regular phone,and it works quite well too.You will have dificulties hearing the other party only in very noisy locations.On the other hand,i might have great hearing 😃
BTW: Sidetalking is not that bad.
yes you are right GhostDog you can hear but, as you said in noisiy palces you have to sidetalk 😊 sidetalking sometimes a bit weird looking thing but if you wanna play thps, tomb raider, wach movie, listen to mp3 or radio tc. you have get used to side talk MarkZGR81 😊 and as GhostDog mentioned sidetalking is not a bad thing😊
I actually find talkin into it like a normal phone a lot better!! You need to crank up the volume a bit, but it sounds a lot clearer than if you were side talkin......and you don't look so much of a prat when you do it!!!!!
I love posing so i love sidetalking!
trust me chicks dig side talk, they will swarm you!
side-talking is major cool and works fine. Turn the volune up a bit. <it takes a bit of getting used to but then, I actually like it!
