SabZ- regarding film guide
2 replies · 2,057 views · Started 21 November 2003
sabz i did everything your guide said except renaming the audience thing i just changed the setting on a preset template thing..
but anyway i go to play it on my phone it freezes after a second but the sound keeps playing it plays perfectly on my comp using realplayer.. and when i pause it on my phone then press play it is where it should be if it hadnt froze but still only plays for a second or two
any help would be appreciated
cheers
Try encoding a different video. You may find you have a corrupt video.
Also make sure no other apps are running at the same time. I sometimes had the same problem when more than 4 apps were running in the background.
yes same thing happens to me when there was some other applications running on the background...
