Vrally
3 replies · 2,392 views · Started 21 November 2003
I cant seem to install the demo on my P900 😞 After it installs part 1, it restarts my phone (Gives me the restarted phone to improve performance message, then I connect it back then and asks me to install part 2 but when I click ok it gives me an error that part one hasnt been installed properely.. weird!!!
This is the error that I get after installing version 1. It restarts the phone and gives me the message below. Then my phone restarts with a distorted screen 😞
Attachments: vrally error.jpg
That is strange!, you are using a P900 aren't you?...i've never had this "restart to improve performance" message yet...perhaps try installing "switcher" and close all running applications before installing VRally?
Other than that, backup contacts etc and a hard reset?😞
Yes I am using the P900. I solved the problem by reformatting the 128 duo. after popping it out of the P800 I immediately used on the P900, this seemed to be the culprit. Eversince then I have had no problems at all!
