Anybody smart enough to know how to remote sync over GPRS to an Exchange Server?
If so, instructions would be great!!
Cheers
Nick
Cheers
Nick
If you have POP3 or IMAP4 access enabled, then you can use that for email "synchronization"
Buy a SyncML Server product that supports Exchange, and use the SyncML client for the phone.
Other solutions might exist, but I'm not aware of them.
Thanks for that...I already do the mail as you said, but the SyncML server piece I was not aware of...
Can remote sync help at all? I do not own the server, but have a hosted solution and am not sure they will add the syncML...
Cheers
Nick
I saw this was just released on Handango, in case it's what you're looking for: http://www.handango.com/PlatformProductDetail.jsp?siteId=1&osId=359&jid=5793C6D817BEC116212396D7C5162949&catalog=0§ionId=0&productType=2&platformId=4&productId=92714
...yes, I had seen that...I was hoping to sync without additional software on the server as I do not own it...just dreaming??
Cheers
Nick
You could try out a push email service that works with the P900.
It provides real-time access to corporate or pop email.
I have been using it with the P800 and it seems pretty stable (despite being a beta).
I think SEVEN is still offering a free beta of it - SEVEN Personal Edition. Check out the program info:
http://www.seven.com/Products/Individuals/Personal_Edition/Beta.html
They also appear to have an enterprise program too - not sure what is involved to get into it though.
BTW O2 xmail and Orange Office Freedom are SEVEN.
