where is the chat program?
3 replies · 2,346 views · Started 22 November 2003
the new program which sony ericsson said the p900 would have (and if you go to gprs counters, you'll see the chat timers)...i can't find it in my phone
Quickshare(tm) is actually not an application but a process that allows you to capture media(video or pic) and immediately send it to your contacts!
As you can see, when you launch the communicam, there are options like "message video" and "message picture" to ensure that the media you take can be supported by the messaging function, on the P800 it didnt have this so a lot of people were asking why they couldnt send picture and video when in fact there media was too big for MMS to support. Another is that on the bottom part of the cimmunicorder, thre is the MMS button which gives you the option to send the media that you just took right away as to the old way of doing it which was take picture, exit communicam/corder, go to MMS and load whatever you want to send from there.
It is basically the shortening of the process of sending media.
Hope these helps.
i remember there was an option to send the current photo currently taken by going to send as mms or something like that in the p800, but it was sooo long ago since i used it though, 🙄 lalalalala
doesn't that mean that the z600 and the t610 also have this feature implemented? as on the side of their boves, it says "quickshare" (TM) plastered on it
