How do i install symbian programs? Transfer them to mmc with a memorycard reader? Or with PC Suite?
How to install symbian programs
you canb beam it through IR or use the PC suite
I never did it with PcSuite but with IrDa (InfraRed). Works fine.
If you download a .sis file from sites like this one ALL you have to do (when your 6600 is connected to the PC trough IrDa or BT) hit the filename and the rest you can read.
But you DO have to install the Suite first, because it uses some files from this installation.
Good luck.
