Opera doesnt work
3 replies · 2,206 views · Started 24 November 2003
Im a user in India,Installed Opera in my 6600.When i try to connect,it just shows connecting but doesnt load anything.
I can normally connect using Services.
Do you have an GPRS Internet Access Point defined & does your mobile subscription allow access to it (some operators limit full Internet access; either by not allowing it at all, or by having a special plan or at least additional charges)?
have access point defined.Operator allows full access.Doris browser working fine but i want opera to work.
ALsoo my clock delays automatically,and logs are usually behind the actual time.Plss help.my software version is 3.42.1 16-10-03 NHL-10
went to service centre they said they upgraded but its still the same version.Seems they didnt upgrade ??
Hello there, which service are you using ? I am also from India, and am going in for BSNL GPRS. I have upgraded to opera 6.20 and am waiting for the service to be active.
Which other browser are you using to access net ?
