Is it possible to uninstall all the rest of the appforge aps and just leave the one needed to launch the apforge based applications? Man it takes up too much space 😞
appforge on P9
Too many files is this normal? When it says 0kb does it mean its alright to delete it?
Hey wait a minute, I was suppos to uplad a pic and it seems that uplad pictures button has dissappeared...
when i uninstall one of them which says 0kb, it removes some other things too, i think you can remove the "more apps" one?
When you say you think, are you sure? 😊 I have you tried this? 😊
although it's such an easy thing to try, i'm really lazy and can't be bothered, hehe, but i know it's an easy thing to do though because you just uninstall one of the sub apps that come with app forge and then see if it still works afterwards, if not, just reinstall app forge, i'll go and try it tonight....maybe 😃
you can remove the "more apps" but need to leave the main and the modules
