Worldmate connection problem
2 replies · 2,745 views · Started 24 November 2003
I have Worldmate (registered and paid 😊 installed on my N6600. Furthermore, I have a working GPRS over HTTP setup on my operator (Telia - Swedish). All apps I have been using connects to the internet perfectly fine except Worldmate. I get a Connection Error everytime I try to download updates for weather and currency rates.
I had the same problem with the TRy and Buy version and assumed it was due to it being unregistered.
Does anybody have a solution?
/GG
grave digging here - but - i have the same problem with my Sendo X. do not count on getting any support from the manufacturer either (mobimate). it would not register with try/buy, nor would it connect TO register. bad product with horrible customer service ans support IMHO - unless someone else can answer the original question...
Mordred
I've used it and it connected (haven't put it on my current phone, but used it on two previous ones) just fine using an Internet access point. It worked also while travelling outside my home country (roaming).,
