video full screen?
9 replies · 2,995 views · Started 25 November 2003
sorry pal but this is not what we consider as fullscreen when you still see the buttons below
It says 3650/7650 so will it work also in 6600 ? i would not like to mess my phone again 😉
HI!..
i think that FullScreen Video is not really needed...
Because the max resolution standard for 3gp format
is actually 174 wide ... so.. if you put that full screen
rotated 90 degrees (to keep the aspect)
you will get a 208 x 176 size...
and i think that enlarging 176 (original X size) to 208 pixels
the only thing you will get is a more blurry image...
Then you will need to get away from the screen to see it better
.. and "far" mean "smaller" ... so... like you can see all
is relative ...
I think is better to keep the original size.. and THANKS
GOD.. the standard on 3gp are 174 pixels wide 😃 same
TFT screen X resolution on 6600 😃
cya!
juzu,PvPlayer can play Audio and Video,you just have to encode it properly.
AEFOX,that is not to max resolution of the 3gp standard if there is any.PvAuthor can encode videos up to 320 x 240.I don't know if the Series 60 version of PvPlayer can play them but the UIQ version certainly can.
Yep!.. you right...
for normal Smart Phones that is the limit (174 x 144)
But!.. on Pocket PC or SmartPDAPhones you can get more..
like 320 x 240...
On 6600/3650/7650 none player can play that video size.
cya!
