The error is:
"Sync"
(x) Type Misspatch, or the value "2003-11-26" in the condition is not valid.
Following a message that sync is aborted.
The date is always one day ahead of the present day.
Syncing all other items but the calender is OK
I have tried the following on requests from SEM support.
1. Repair Outlook
2. Reset P900 / reset Calendar only
3. Re-Install PC Suite (2.01)
4. Re-Install Drivers for SyncStation
5. Created a new .pst folder locally on Outlook , added a calenar
Folder, set the sync to tync againts this.
6. Syn on off-line mode.
I am running Windows 2k and Office 2k.
All results end up at the same error, once the date was one day behind. but the error message itself was the same.
I am also syncing this P900 with my Mac running OSX 10.3 and iSync 1.2 and this works GREAT, no problem so I am guessing that there is a problem on the Windows PZ.
Anybody has a solution or a workaround?
Are there any other PC sync softwares that I can buy that will work better??
Thanks. Jonas
