Memory Problems
11 replies · 2,809 views · Started 25 November 2003
Hello guys, I have a problem with my 3650. I've installed various applications with Bluetooth connection, and I always save this applications on 128MB MMC.
I always delete the inbox messages where bluetooth sent files, after the installation.
But I realize that Phone Memory is dropping each time I install a software. Now I have 350k of free memory on the phone mem. and 110MB on the MMC.
What should I do??😕
Did I forgot to delete something?? Or the shortcuts created by the app. eats so much space?
Help!!
Try moving your messeages to your MMC card.
You'll free up some memory that way.
Also... what programs are you using (post a list) ?
Maby you have too many running programs in the backround...
I always delete my incoming messages... now I see I can set the incoming files to go to MMC... THANK YOU again!!😊
I`m using a lot of apps, must of them are shareware I`m testing (all of them at MMC)
Moto Racer
Video Recorder
Image Plus
Bounce
Terra Force
Psiloc Infrared
Ebook reader
Triple Pop
Bemused
Card Deck
Camerafx
Seleq
IQ
miniGPS
Zipman
PhotoSMS
FExplorer
Phone Secure
ReadM
Pallete extender
Terraforce
The problem isn't the space on the MMC...
With all those programs in RUNNING MEMORY
witch is smaller then 4 MB you 3650 is at it's limit.
Try to unload some of those ....
(The phone copies the program in running memory while executing it. That's why your memory is full)
I have the same problem too...
In my MMC (128):
App Man, Stacker, eFile Man, eProfilePro , World Clock, Switcher, sTools, Photograph v2.2, ETI Camcorder, Blacklist, Launcher, Skin Editor.
My Phone memory:
477b Calendar
34 kb Contacts
5 kb Messages
(0 documents, 0 images, 0 sound files, 0 video clip, 0 applications)
1136 kb memory in use
2957 kb free memory
Try this:
- you must compress your contacts with compress apllication (I use stacker).
- dont use the background image.
- n the last try to delete files on folder (C:\system\install\...).
Before you doing this you must back up the phone or back the files in that folder....I back up all this files (C:\system\install\...)in my MMC using file manager. I copied all the files n paste in my MMC (in special folder) because sometimes the applications still need this files to remove the application
I still trying to reduce the memory in another way...Perhaps someone could give us in another way....
i don't have a problem with my mmc.
i"m just curious if u guys use ur MMC in receiving SMS? Coz i'm currently using my phone memory and it's kinda slow when i read my messages.
I don't think stacker on the 3650 is such a good idea...
It will only slow your phone down.
I use MMC for messages and it is ok.
What do u mean slow access to SMS ? It is a new generation phone, it should open SMS in very short time !
so if u keep ur sms and applications and pictures of mmc, what's in ur phone memory then?
Slow. when i open my inbox or folders, it will took a few sec. before it opens. Unlike when my fone's still new, d msages/folders automatically opens
It is maby a little slow...
But I have tons of MMS (they are great !!!) and I can't complain about the access time.
And another thing... don't leave programs running in the backround when you're not using them. Press "EXIT".
You can see this if you long press "Menu Button".
