I hadn't got around to offloading my daily messages coming in - with gif attachments and finally today the worst happened. The phone AND MMC memory are totally full so that only the Nokia logo shows up on poweron and eventually says either that such-and-such app (mTelSvr, etc) aborted or more frequently - "Memory Full" with an OK. Pressing OK just sits at the NOKIA logo.
ANY idea how to get around this?
Help! 3650 Memory Full Can't boot. Nokia logo only!
Maybe try to use an empty MMC-Card - or, if you have a card-reader in your PC empty your MMC...
Maybe that helps you to start the phone...
- Then I would suggest, that you free up some phone memory...
Thanks. I tried that. Deleted some images off of the MMC but the phone memory itself is so full that even the menu and telsvr apps don't start.
I'm just not looking forward to the Nokia techies doing the proverbial 'reformatting the disk' and losing my contact info.
Try using an empty MMC card... Maby it will boot that way.
Other than that it's only a reset (formatting) I guess...
By the way ... How did you manage to get that memory that full ??? 😕
Oh... and another thing...
Try moving your messages folders to
the MMC card if you know you have a lot of mail. That way your memory stays clean...
Good Luck !
Thanks. It's too late for that.
No matter ... you'll know in the future...
