The new version of Tracker is out and they are some great new features !
Some new codes and commands who are really helpfull like a buffer of the today page and a 401 command wich allow you, in full skin, to see the system status panel
In short :
"Auto remove shortcuts for deinstalled apps" option added. If activated (on default) then when you deinstall any application, Tracker will automatically remove a shortcut to this application from desktop as well (if any).
But if you use more than one memory card for your device it will be better to disable this option. So when you remove the memory card Tracker won't auto delete shortcuts to applications located on memory card, but will mark them with "disabled" icon.
"Reload" command added. Could be very useful to completely refresh your desktop after swapping memory card.
Tracker autostart function added.
After "close all apps" command fulfilled the current page is automatically refreshed (in order to show updated memory size)
Tracker's menu was restructured. Non-essential options such as 'Reg. info' and 'About' now can be found in More sub-menu.
"Snap to grid" option added (with customizeable grid size).
"Popup Tracker" button behaviour was improved. If you press the same button that pops up Tracker from background, but when Tracker is in foreground, Tracker will scroll between current skin pages.
The ability to use the jog dial up and down buttons while Tracker is in foreground and current page includes Today view to scroll through days/weeks added (optionally). If this option is disabled, the current page doesn't include today view or Tracker is in background then when you press these buttons Tracker will perform default action you have assigned in Tracker "Settings" dialog.
"Cache today view" option added. If enabled you'll sacrifice some memory in order to open page with today view without ANY delay. Today view resources will be constructed only when open today view for the first time (next switches to this page will be with no delay!)
Now Tracker won't be automatically closed by system while in background, system will look for something else to close!
204 command (Compact mem) fixed
104 (screen lock) command fixed
"New Phone Call" command fixed.
401 command added. Shows/Hides system status pane. Works only on complete full screen pages. Warcraft3_cs sources updated. Here you can see an example of how to use this command.
When you create a speed webpage shortcut now option about icon transparency are always visible
Now Tracker can import skins from "OTHER" folders accessably to you from PC Suite,
On device they are: c:\Documents\Media files\other\
d:\Media files\other\
not only from inbox like before. Or, if you're familiar with FileMan you can simply move ztr files to \system\apps\tracker\skins\ folder without any import.
Small cosmetic and rendering improvements. (When shortcut is moving now it doesn't always redraw status line)
Now Today view automatically becomes refreshed at midnight in order to auto change the date.
When current skin was somehow deleted (outside Tracker), no more "NoSkin" panic. Now Tracker will automatically switch to the default skin.
Now available in English and German languages
Many more minor improvements and fixes.
