Does 6600 surf over BT ?
4 replies · 2,123 views · Started 26 November 2003
Is it possible to surf over BT with Opera on the 6600 with the dummy Bluetooth-GPRS connection ?
With a 7650/3650, I had no problem, but it seems it's not the easy with the 6600.
Any idea ?
Have you check this??
If the remote device you connected to uses Windows 2000 operating system, you must ensure that it has already enabled the "Internet Connection Sharing" function.
In the desktop of Windows 2000 of the remote device which provides the Network Access service, select Start > Settings > Control Panel > Network and Dial-up Connections.
Right-click on Local Area Connection icon; select "Properties" in the pop-up menu.
Select Sharing tab in the Local Area Connection Properties window.
Enable the "Internet Connection Sharing" function in the Sharing tab.
When the warning window appears, press Yes button to confirm the change.
And it is same in XP
Found this article from Bluetake web site
We don't even know ourselves. Some people have told me they have it working on the 6600, but neglected to tell me how...
There are some differences between the 7650/3650/N-Gage (Symbian 6.1) and the 6600 (Symbian 7.0s) in how connections are handled and that affects the abillity to surfe over BT. Please post here if you find a way to get it working.
Dag Olav Norem
Opera Software
