Hi! just downloaded, the now fully N6600 compatible, Psiloc screensaver version 1.52. But. it doesn't work; Installs fine, and the application start, but there it ends!
Preview doesn't work, or doesn't start after the given time!
Version 1.40 works fine (except the animation feature)!
Anyone ?
Psiloc Screensaver 1.52 problems
Where did you download the version 1.52 can you please give us the link. Thanks! =)
go to psiloc.com
After install system-tools always reboot your phone, then it works.
I test out SC v.1.52, it work the same way then v.1.51.
But i was reboot first the phone.
S�mi
I'm not THAT green!! I always reboot.. tried 1.51 also, to no avail! well well, I'll use 1.42 'till neXT version..
BTW: Does Anim GIF's work 100% in version 1.52 ?
I m sorry, dont wanna say tzhis.
i only tell how it was working with my mobile.
(with those versions.)
best is u send a mail to the support of PsiLoc, maybe they know a way to work it out.
regards
S�mi
HI, the new version 1.60 works fine! I'm happy 😊
hi i have installed an older version of screensaver 1.15 it works but the only problem it is i am not able to uninstall it how do i go about it please let me know when i go in manager and ask for remove it says ssytem error and when i also try to remove the extended profiles pro it says systme error please help
