How to remove flip
7 replies · 2,474 views · Started 28 November 2003
Anyone know how to remove the P900 flip...I know we get a screwdriver etc, but cannot immediately see how this works...
Cheers
Nick
Lift plastic tap in the middle of the flip....remove screws, replace small plastic tab with bigger plastic tap...don't loose screws...job done. 😉
when you buy the p900, their should be two extra screws, the flip off...flip, and a screwdriver, along with the little handbook on how to attach and remove the flip
i dont understand or maybe i do i guess but i want to be sure before i break it...
see do i have to lift the plate in the middle like with the p800 to get it out of its clips or do i have to do something else...
i dont know because i didnt get the little book u mentioned...
at the bottom of the p900, their is the standard connecter pins (like the charger), near the removable flip in the middle, there is a tiny whole, jab something in their and the flip will pop off, you'll then see two screws, remove them, and the white plastic bit of the flip, push it upwards and then pull it out and the flip will pop off
do NOT use the stylus as instructed by the small printed guide.
I broke one stylus in the process
@#Q!#$%^@!#
