will a p800 play a movie with 320*208 (in full-screen mode of course ) ?
if not, what is the largest possible dimension? (i hope it's not the standard 176*144 )
when playing the movie, tap on the screen and you'll be blessed with the jerky full screen mode,
The default P800 video player doesn't support that size. The 192x144 setting in PV-Author is the highest, and using other encoders you can go even a little higher, but nowhere near 320x208 (widescreen). The P900 videoplayer however does support higher resolutions such as 320x244 (PV-Author).
If you have the beta video camcoder of the P800 installed you can play 320x208 video and very smooth compared to preinstalled packetvideo player that is never able to give more than 5fps in full screen mode! 😃 😛
That's right, but the Camcorder app only supports files that are on the internal memory. So that isn't really very useful
BIG MISTAKE!!! If you have any file manager and you go to the video directory of your MS-Duo and just click on the file of your video it will run with camcoder's video player! I have one 36MB movie on my MS-Duo and I can see it full screen with smooth playback thanks to my file manager!
but this camcorderapp doesn't support audio.
isn't there a video player as good as camcorder, but WITH SOUND?
wenmi,i've heard it does,only AMR though.I can't say anything for sure because i don't own a UIQ device.
what camcorder apps r u guys talking about??
Well, at the time we were talking about it, it was only a beta, but the full version has been released a while ago
http://my-symbian.com/uiq/applications/applications.php?fldAuto=594&faq=2
thanks
