How to get the best video quality...
3 replies · 5,836 views · Started 29 November 2003
see guys the video u get with the p900 is wayyy..to clear and is very...smooth(super clear)
but i wish i could render clips from PV Author in the same high clear quality ......i've even used mpegable but they lack the high quality look......(i find mpegable a little smoother and PV Author slightly sharper....and with better sound quality...)
I've rendered clips a million times with different settings but still have'nt been able to get anything close to the quality of the clip that comes with the p900 (The Guy playing Golf thing)
could any one tell me if there is a way to get that Quality....with other clips....
Same here mate i try every thing you try but no luck. Any body else know?? help would be nice
Well surely using PV Author you can actually encode to near broadcast qulaity if you put the settings high enough.
I havent seen the clip you are talking about with the golfer but I cant imagine its something which cant be done - you have to remember the source file they would have used would probably be better than any source file you might have.
How long is the clip and waht is the file size and resolution of it I'll see if I can knock something up similar...
P
I managed to get high quality vids on my phone.. All on my site. 2hrs + on one 128mb stick...Even in widescreen mode.
That was done about 3 months ago.. Quality was fine.. You can kinda make out some details from this bad pic I took of it..
