remove files from manager
5 replies · 2,702 views · Started 29 November 2003
hello,
i installed world clock on my 6600 but it wont open so i decided to remove the program but now it can't be removed. other files can only this one can't.
any suggestions?
tnx
i already installed the Appman, but the problem now is i can't find the world clock in appman. how do i do thit?
tnx
----%------------------------7d3154c6b8
Content-Disposition: form-data; name="parseurl"
yes
tnx
yes
on the appman, options, apps installed, try scrolling down until you reach W
are you sure it's still on your phone???
i can see the world clock in manager but can't find it in appman.
and one more thing, how do i delete files using appman coz the options to choose from are start application, add to favourites, more - (application infor, close all apps, compress memory,restart device), settings - ( show all apps, excude ROM apps), misc - (about, add to go to, register info.)
when you ran appman, there are tabs: summary/running apps/processes/open files/installed apps
application info and check the path
use file explorer to check if you can delete or access the path given
