mbm
4 replies · 1,938 views · Started 30 November 2003
Hi goto http://nowhere
pick the mbm wizzard.
You can open it that way,
save the images in bmp format, manuplate them,
use the mbm wizzard again to repack them to the mbm & upload it to the phone.
Originally posted by andredias_
how can i open mbm?
JyriK edit: no wares here, please.
but when i put them in the phone where i open?
you can't open it.
you have to install a theme like climber theme and just replace the existing .mbm with your new .mbm and rename it to climber
Hi, do not put the mbm wizzard in the phone. Its a PC stuff..so keep it in your PC....use the mbm wizzard to open an mbm file..
usually available in the Climber theme could be
C:\system\appz\skins\<dir>\Climber.mbm or
E:\system\appz\skins\<dir>\Climber.mbm
get this file to the PC, open it with the mbm wizzard,
save these pictures.,
Edit them,
Pack them again using the same mbm wizard.
put it back in the location from whre u picked it as the same file name,
MARIRS
