P900 Stylus/Styli???
3 replies · 1,232 views · Started 30 November 2003
Does anyone know where I can get a replacement stylus for my P900?
It only came with one and not the usual two and my little daughter (Bless!!) has managed to get her hands on it and loose it for me!
I live in the UK.
Have tried SE and their answer was "it's not made as a replacement part and only comes with the phone" - surely I can't be the only one with no stylus for thie P900.
Please help!!
I thought mine only came with one, but I discovered it under the insert in the box...check that, I also found my Duo in there too 😉
I can't belive SE are saying that it's not a replacement part....it surely is!!, in fact it has to be!...just give them some hassle down the phone.
Failing that give some service centres a call, they can usualy get any part of the phone for repair
aside from the one that came with the phone I had one extra one in the box you should see it right away when you open the box and take out the manuals 😊
Hi Guys,
Thanks for your kind words!
Have double checked the box and removed the packaging, but no spare stylus!
Will try hassling SE tomorrow, seems to me that their Customer & Phone support is sadly lacking!
Thanks again,
nppage2000
