n-gage
0 replies · 728 views · Started 30 November 2003
Hi all. I am not ready to drop my phone out the window, but i am having problems. I have installed all the apps from the cd. I used the nokia connection manager and selected the usb connection but my pc doesn't see the phone. Is bluetooth the only way?
The usb works for the mmc but how do you use and connect to pc suit? does usb work? Do you need a seria cable? Does usb do the same or do i have to get a bluetooth pci card?😕
